Home Forums Products Stompboxes H9 Crashes | H9 Max Dark 5.8.5.1 Crash Reply To: H9 Crashes | H9 Max Dark 5.8.5.1 Crash
#154248
l_sap_ccs_crm
    bohan wrote:
    l_sap_ccs_crm wrote:
    I just bought the pedal, and would like to know if this is a sw or hw issue related, because I’m in Brazil and I hardly doubt that there’s someone able to fix it here.
    Are you using the factory power supply? Have you tried factory reset your pedal? (Power up your H9 with pressing and holding the right footswitch and the big black konb)
    What is the MIDI IN for? After you reset your H9, please let us know if this issue still happens without MIDI connection.
    Yes, I am using the power supply provided by Eventide. Tried the factory reset – nothing changed.
    The cable in MIDI in is from my fc, if you’re wondering, I did all the things all over again with the cable disconected and nothing changed again.
    Tried the Eventide Diret Update…t erased the firmware and now, when I plug the power chord, it lights up and then goes off….nothing happens or appears o the display.
    I don’t know what else I could do right now…
