Home › Forums › Products › Stompboxes › H9 Rotary Preset (Default To Other Speed When Loading Preset) › Reply To: H9 Rotary Preset (Default To Other Speed When Loading Preset)
#154268
bohan
    realdealblues wrote:
    Hello all,
    This seems like it should be simple but I can't figure out how to do this (seems like it easily should be).
    I modified a factory Rotary preset and saved it as a User preset on my iPad and then loaded it to the H9.
    When I pull up the patch it always is on the "fast" speed mode and I want it to start with the "slow" speed by default.
    I thought simply opening the patch on the iPad and having it dialed in slow and clicking save would default it to the slow speed but it doesn't.  As soon as I pull up the patch it's always the fast spinning sound.
    Is there any way to easily change this?
    Thanks for any help.
    I just saved a user preset with SLOW on. Then I clicked this preset it's loaded with SLOW mode (the middle footswitch in the UI is engaged)
