Home › Forums › Products › Stompboxes › Need help creating a harmony effect for a project › Reply To: Need help creating a harmony effect for a project
#154292
    brock wrote:
    … You can also assign an AUX switch to switch between the HEEL TOE extremes of any expression pedal mapping.  Great way to shift between two sets of harmonies; faking a HotSwitch function.  Unfortunately, I believe that will only be a momentary action.  You’d have to hold the switch down for the duration of the harmony change.
    There I go, quoting myself again.  Forgot to mention:  If you have an AUX switch capable of latching action [BOSS FS-6 or similar], you can snap between two sets of harmonies at the HEEL TOE of an expression pedal mapping.  Assign TIP, SLEEVE, or T+S to Expression Pedal.
