Home › Forums › Products › Stompboxes › H9 as a master midi clock and BPM lower limit › Reply To: H9 as a master midi clock and BPM lower limit
        March 12, 2020 at 6:26 pm
        #154302
virtualsamana wrote:
I am interested in purhasing the H9 (it looks awesome!). One of the functions I would like to know is if it is possible to use the H9 as a master midi clock to sync other gear (synths and drum machines) and would like to change the tempo (BPM) dynamically with assignable rotary dial. I would like to know if this scenario is possible and if so, what is the lower limit of the BPM. IE does it go down to 30 BPM.
Yes, you can use H9 as a master midi clock. You can change the tempo by tapping the footswitch, using auxillary switch or MIDI. The lowerest BPM on H9 is 30.
