Home Forums Products Stompboxes User scales or custom scales for H9 Harmonizer Reply To: User scales or custom scales for H9 Harmonizer
#154312
Bodde
    rokiko wrote:
    bohan wrote:
    H9 doesn’t support custom scales. However, you may use an expression pedal or a MIDI controller to change the Pitch/scale parameters in real time while playing.
    Thank you very much, @bohan
    I had feared that.
    It is a pity, because to use a pedal to change the parameter in just the right moment, is too much to do (and to think) for an old man, when he is playing with the band. wink
    Best wishes! yes
    I agree. Having to switch pitches with midi is not convenient. I think you have to look elsewhere then. Good luck!
