Home Forums Products Stompboxes Hiss Noise Mixing Link Reply To: Hiss Noise Mixing Link
#154371
JWaltz
    Jonathanbm wrote:
    Hi Joe,
    My setup is DPA 4099 -(XLR, into Mic/Line In)-> MixingLink-(XLR, through DI/Line out)-> Behringer Xenyx 802 mixer -(Jack/Line, through Phones))-> Beyerdynamic DT 770 Pro 80 Ohm.
    The MXLNK gain is set to 1 o’clock, and I have the “GND Lift” and the “-20” activated.
    Connected to my MixingLink, I have a Neunaber reverberator.
    I play on a trombone.
    I have just tried to connect my headphones directly to the MixingLink, both through the inputs “To amp” and “Phones”  and there are slightly less noise here. But here, the volume can’t get up to a niveau that is comfortable enough, and it’s also only mono through the “To amp” input, as it should be.
    I have tried it on a PA-system as well. Here are do the same, except for the Behringer-mixer, I connect the “DI/Line Out” to a normal XLR-input. Here I have the same issue with the noise.
    Hi Jonathan,
    What is the DI/LINE out level set to?
    This switch is in the bottom. DI setting should make it quieter.
    lmk, joe
