Home Forums Products Stompboxes Dump & Restore Reply To: Dump & Restore
#154409
bohan
ivan_lechev wrote:
Hi, guys, I'm a proud user of H9 Max, and I have a question that might sound stupid: In the manual there is a very clear explanation about how to dump all presets and system settings alltogether to a, say, DAW or a computer or a sequencer, etc. However, there is no explanation on how to load that dump back to the device when needed. As I'm using the device on several completely different projects, I badly need to know how this happens.
Thanks in advance,
Best regarda,
Ivan
Well, if you just need to manage/export/import preset lists. You can do that in H9 Control.
If you want to restore system setting via MIDI’s SysEx facility, the manual says about it on page 28: https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/H9-UserGuide.pdf
