Reply To: Pitch Factor: The Update Saga Continues
Home Forums Products Stompboxes Pitch Factor: The Update Saga Continues Reply To: Pitch Factor: The Update Saga Continues
#154413
bohan
Pitch wrote:
Doesn't work at all with USB, never worked in all this years. My last hope was to try update it using the MIDI ports. I can select the ports 1 and 2 with the updater app, but then all i got is a spining weel for ages. Do i need to do something in the pedal itself in order to update it with MIDI?
Did you see your PitchFactor in Direct Updater? Did you boot it into Update mode?
