Home Forums Products Stompboxes Dump & Restore Reply To: Dump & Restore
#154417
    If you just send the dump back to the H9, it should load it.
    Note that there is a small element of risk in using these dumps – if the data was corrupted either in transit or by the computer, you might end up overwriting the pedal with bad data and losing its presets. These dumps are best used as emergency backups, rather than regular transfers. You should consider using H9control instead.
