Home › Forums › Products › Stompboxes › H9 problem – display issue › Reply To: H9 problem – display issue
#154421
tsternfeld
    Oh, I didn't realize that other than the display, the unit was working correctly (does this include the Bluetooth connection?)
    This sounds like a hardware malfunction of some sort, then.  If the switches are also inconsistent, I'd suspect an issue with the ribbon cable between the two units.  You or a handly friend might be able to re-seat that cable at fairly low risk.  Otherwise, I suspect you'll need to get in touch with our support crew directly for service information,  support@eventide.com .  Linking them to this thread will save you some time explaining.
