Reply To: H9 as a master midi clock and BPM lower limit
Home Forums Products Stompboxes H9 as a master midi clock and BPM lower limit Reply To: H9 as a master midi clock and BPM lower limit
#154424
tstern
georgerterry wrote:
Hi there,
I'm trying to use my H9 as a clock source for a Mother-32. Unfortunately, the Mother-32 doesn't seem to register.
I've got MIDI output mode set to transmit and enable midi clock output set to yes.
Any ideas?
Cheers!
Do you have any way you can split this signal to debug it?  I.e, if you run the H9 to a MIDI interface or some other piece of gear, you might be able to confirm that it's sending the MIDI clock out.
Do other MIDI messages appear to register on the Mother-32?  From the manual for that, it looks like if it receives a MIDI message, the red LED by the MIDI jack should blink; do you see that happen?
