Home › Forums › Products › Rackmount › H8000FW boot loop problem › Reply To: H8000FW boot loop problem
#154435
    It really does sound like the battery, but you have changed it several times. It would be good to measure the battery voltage in place (should be around 3.0V).
    Otherwise I fear it is a hardware fault, probably a bad NVRAM or RTC as the test messages suggest.
