Home Forums Products Rackmount H8000FW boot loop problem Reply To: H8000FW boot loop problem
#154439
Sadly, it’s not under warranty (I’m not the original owner). I was hoping to eliminate any relatively simple possible causes initially, for instance in the past I have found replacing the socketed DIP ICs can rectify things.
Sending it in to be fixed could get quite expensive, however if necessary I’m assuming Source Distribution here in London is the nearest repair centre. I will contact Eventide support as you suggest.
