Home Forums Products Stompboxes Pitch Factor: The Update Saga Continues Reply To: Pitch Factor: The Update Saga Continues
#154440
Pitch
    bohan wrote:
    Pitch wrote:
    Doesn’t work at all with USB, never worked in all this years. My last hope was to try update it using the MIDI ports. I can select the ports 1 and 2 with the updater app, but then all i got is a spining weel for ages. Do i need to do something in the pedal itself in order to update it with MIDI?
    Did you see your PitchFactor in Direct Updater? Did you boot it into Update mode?
    Pichfactor OFF
    press middle footswitch + encoder button
    I power PITCHFACTOR
    I see UPDATE on PITCHFACTOR
    I connect the USB cable (also tryed it with the cable inserted before powering the PITCHFACTOR)
    I launch H9, and it doesn’t find any pedal
    I launch DIRECT UPDATER
    Doesn’t find any pedal either.
    MAC OS 10.15.3 & Lastest Windows update // They both do the same.
    I never ever got my PITCHFACTOR to comunicate with a computer with USB.
    Thats why i was trying the MIDI way of doing it.
