Home › Forums › Products › Stompboxes › Pitch Factor: The Update Saga Continues › Reply To: Pitch Factor: The Update Saga Continues
March 30, 2020 at 1:01 am
#154442
nickrose wrote:
No obvious reason why it would work with MIDI and not with USB but worth a try.
Make sure the USB is unplugged before powering up and then using the DIN MIDI.
Is it possible to get the latest update in a file so i can select manually and update it?
