Home › Forums › Products › Stompboxes › Pitch Factor: The Update Saga Continues › Reply To: Pitch Factor: The Update Saga Continues
#154443
bohan
    Pitch wrote:
    Is it possible to get the latest update in a file so i can select manually and update it?
    Yes. But you would need to use the Direct Updater via USB, cause it's designed to work with USB. Could you try USB connection again with the Direct Updater? H9 Control cannot work with the PitchFactor before it is updated to the lastest firmware. That's probably why the USB didn't work for you before.
