Home Forums Products Stompboxes Time Factor connection issue Reply To: Time Factor connection issue
#154446
tsternfeld
    I can only see one of your error messages, but based on that:
    Do you see the Timefactor in your Device Manager window?  It should be under the "Audio Devices" category.
    Do you know what software version your Timefactor is running?  Some of the older software versions that came out before H9 Control was released need to be updated with Eventide Direct Updater before they can be used with H9 Control.
