Home Forums Products Plug-Ins Multiple Plug-in formats (VST, AU) and installation size Reply To: Multiple Plug-in formats (VST, AU) and installation size
#154459
DGillespie
    Hi cljfford,
    Unfortunately, Logic and Reason look for the plug-ins in two totally different places, so install both will double the amount of space the install takes.  However, as you notice, the plug-in is only about 30MB, so it's not a very big file.  Normally, if you want to use the plug-in in both DAWs you'll install both plug-in formats.  However, if you want to use it in Reason only, VST only is fine.
    Good luck, and let us know if you have any other questions!
    Thanks,
    Dan
