Home Forums Products Stompboxes Pitch factor: Killdry and Dry/Effect Mix? Reply To: Pitch factor: Killdry and Dry/Effect Mix?
#154497
bohan
    Bob_B wrote:
    I have a Pitch Factor and have it set to impliment Killdry. What effect does using Killdry have on the Dry/Effect Mix? Does that effect become a volume control or what? In moving the dial around, it wasn't apparent that much was happening.
    All algortihms can use Killdry. It just kills the dry sound if it's turned on. I recommand you check out H9 Control. You can connect your PitchFactor to your PC or Mac via USB and use H9 Control to adjust your settings. Killdry can be set on a global or preset by preset basis. It would be helpful for you to use H9 Control to see the UI of a preset while tweaking it and toggling killdry.
