Home › Forums › Products › Stompboxes › Mix resets to full dry on MIDI clock start › Reply To: Mix resets to full dry on MIDI clock start
#154563
bohan
    SpaceRock74 wrote:
    Hi
    I have Time Factor and Space, slaved off a MIDI master. When the clock starts the mix resets to full dry (on both units), and I have to turn the mix knob to re-engage the effect. Is there a setting to change this?
    Thanks
    Are you sure you are not sending any MIDI CC messages? You can try turning off the MIDI CC mappings for the Mix knob on both units.
