Home Forums Products Stompboxes Mix resets to full dry on MIDI clock start Reply To: Mix resets to full dry on MIDI clock start
#154564
bohan wrote:
SpaceRock74 wrote:
Hi
I have Time Factor and Space, slaved off a MIDI master. When the clock starts the mix resets to full dry (on both units), and I have to turn the mix knob to re-engage the effect. Is there a setting to change this?
Thanks
Are you sure you are not sending any MIDI CC messages? You can try turning off the MIDI CC mappings for the Mix knob on both units.
Thanks for the quick response. The Drumbrute which I use as MIDI clock source has default settings and is sending this on start –
53837,112.1625,24:0,,Start,,,
53837,112.1657,24:0,,Clock,,,
53838,112.1684,24:0,2,Control change,54,127,
53838,112.1708,24:0,-,System exclusive,6,,f0 7f 7f 06 02 f7
53839,112.2245,24:0,10,Note on,42,100,
53847,112.2271,24:0,,Clock,,,
53852,112.2295,24:0,10,Note off,42,0,
53857,112.2321,24:0,,Clock,,,
53867,112.2346,24:0,,Clock,,,
53877,112.2891,24:0,,Clock,,,
53887,112.2918,24:0,,Clock,,,
53896,112.2943,24:0,,Clock,,,
53897,112.2969,24:0,2,Control change,54,0,
53906,112.3533,24:0,,Clock,,,
53916,112.3559,24:0,,Clock,,,
53926,112.3584,24:0,,Clock,,,
53936,112.4123,24:0,,Clock,,,
I will investigate the meaning of these CC messages.
