Home › Forums › Products › Stompboxes › TimeFactor Cycles On/Off › Reply To: TimeFactor Cycles On/Off
April 15, 2020 at 5:11 am
#154596
tmart wrote:
Same with at least one of mine; both with a brand-new Eventide a/c adapter and with FLEX cables.
It doesn't appear that the solder is the issue from what I can see inside although I have heard some folks point to that as an issue on their pedals.
It seems almost like the special 2.5mm post doesn't quite fit the barrels on the cords.
If you are sure that it is the power jack's problem, you may get this from our website and have some tech do that for you.
https://store.eventideaudio.com/collections/accessories/products/dc-power-jack
If your pedal is still under warrenty, you may send it in and we can repair.
