Home › Forums › Products › Rackmount › H9000 Setup Questions › Reply To: H9000 Setup Questions
April 20, 2020 at 7:52 pm
#154652
iVardensphere wrote:
Good to have you on board, David. While my H9000 did connect to the internet and did download the latest version to update itself, the network page comes up as all 0.0.0.0 and IP. IP Config doesn't change this. Strange up factual.
Thanks for the image! The 0.0.0.0 address may be the problem – if you press "IP CONFIG", then "DHCP", it should reinitiate the DHCP request and gie you a proper IP address. Could you try that and let me know if it then shows a valid IP address?
