Home Forums Products Stompboxes Master Volume Does not Work with Crushstation Reply To: Master Volume Does not Work with Crushstation
#154790
bohan
    szabados1 wrote:
    I connected my H9 in the effects loop. When I am in the Crushstation algorithm, the amp Master Volume has no effect.
    Isn't that the Amp's problem?
    szabados1 wrote:
    Also there is a setting for the pedal to select when in the effects loop. When selected the pedal goes silent.
    Which setting is this?
