Reply To: Master Volume Does not Work with Crushstation
Home Forums Products Stompboxes Master Volume Does not Work with Crushstation Reply To: Master Volume Does not Work with Crushstation
#154797
bohan
szabados1 wrote:
The amps master volume is in the series effects loop.  The H9 is the only pedal in the loop  The other algorythms allow the Master Volume to still control the volume.  I have teh Kill Dry Audio in the General Settings set at NO.   When I put this in Yes, the the H9 goes silent.  Not sure why the App states why the Kill Dryis normally enabled when the unit is connected in the amps effects loop.
I apologize but I am not an Audio engineer.
If the current preset is bypassed, and the KillDry is on, there will be no sound coming out from H9. Because KillDry kills the dry sound, and when a preset is bypassed, there is only dry sound.
