Home › Forums › Products › Stompboxes › Quadravox hotswitch › Reply To: Quadravox hotswitch
May 8, 2020 at 12:35 am
#154820
bohan wrote:
birthofahero wrote:
So I know the hotswitch is a “Learn” function but I’m trying to set a button on my midi controller to change one of the voices from a -4th to -3rd and back. Is this possible?
Yes. You can set the expression pedal (ribbon) mapping for that parameter from -4th to -3rd, and then assign the expression pedal (ribbon) to a CC message. Then you can use your MIDI controller to send that CC message to control this parameter.
I think I understand what you mean, I can set the expression value aka hot knob to a CC# in the settings. That allows me to get to the expression settings set by the ribbon (in the app, I think this is what you mean) but what CC command would I send to get me back to the original settings? I think a simplier way to explain would be one CC command for toe up and one CC command for heel down.
