Home › Forums › Products › Stompboxes › Expression pedals for H9 › Reply To: Expression pedals for H9
May 13, 2020 at 7:17 am
#154847
Ok, the M-Audio MGear EX-P works fine for me. However, this inexpensive pedal is hard wired, i.e., the connection cable is not detachable. Which, of course, does limit, if not exclude, using of the pedal in an y-configuration with a switch.
Also, I’ve tried the Moog expression pedal with my H9. This didn’t work as expected. The Moog pedal seems to be sending signals all the time even if in extreme heel position. As result, the display did not show the preset name, presenting some blinking, slightly changing number values all the time instead.
