Home › Forums › Products › Stompboxes › Rose Delay Questions on Aux Switches › Reply To: Rose Delay Questions on Aux Switches
#154882
jac
    Kurt Leege wrote:
    Hi. I love my Rose Delay purchased a couple of months back, but am having some issues with functionality on a 3 button aux switch. I have it set to tap, decrement preset and a/b.
    I noticed my aux tap acts weird also. I would suggest using tap on the pedal & using aux as your Hotswitch. I would think that tapping from the pedal would be the most accurate.
    The a/b works fine. The tap sort of works, but it seems to often either double or half the tap that I put in – and further if I do a longer tap, it will put the initial delay at that tempo, but subsequent repeats at a much shorter interval.
    The decrement preset does take the preset down a notch while flashing, but when the preset actually loads, it goes back to the preset it was on before I tapped the preset decrement.
    I have the latest firmware update with all of the new features. Is this normal behavior for the pedal? Is there anything I can do to get the tap to simply go by the tempo I tap? Is there any way to get the new preset to actually load when I hit preset decrement?
    Thx.
