Home Forums Products Stompboxes H9: Can I use MIDI for program changes and exp, and still use an aux switch for hotswitch? Reply To: H9: Can I use MIDI for program changes and exp, and still use an aux switch for hotswitch?
#154926
bohan
    chrism27 wrote:
    Unfortunately the DPC-5 doesn't allow for custom cc messages as far as I know. Would I need to use a TRS cable for a single button aux switch, or is TS fine?
    Well, H9 can take any MIDI CC messages and map them to whatever functions you like.
    If you want to use a single button aux switch, I believe both TRS and TS can work. TS should be fine.
