Home Forums Products Stompboxes Volume Boost Feature For HotSwitch Reply To: Volume Boost Feature For HotSwitch
#154928
apalazzolo
    I have looked all over for this.
    The “trim” parameter in EQCompressor will do this.  So will the “output” parameter in MangledVerb (this can be used as a boost/overdrive if you turn off the reverb portion.  I believe Ultratap (which has a great delay) could easily be modified by Eventide to do this.  I have asked Eventide to consider it but they have not responded one way or the other.
    People have asked Eventide to modify the “output” slider for every algo (on the right of the Control screen) to do this but it is apparently not possible.
    Good luck!
