Home Forums Products Stompboxes H9 Max – strange, de-tuned sounds Reply To: H9 Max – strange, de-tuned sounds
#154931
gaca99
    No. First of all it happens not every time, so it’s lottery. In general it is related to preset (algorithm) which was used when H9 was powered off. Crystals is incorrectly load when Blackhole was used, but sometimes when Tape Echo algorithm was used H9 loads I’d say “empty algorithm” – I mean when I press activate button it sounds like still in bypass (clean signal without any effect).  Unfortunately I didn’t check in app what algorithm it was. Of course when I change preset one up/down and go back everything is OK. I noticed that it never happened when Chorus or other modulation effect was used
    Yesterday I wanted to check other algorithms but … everything worked well so I do not have nothing new to share with you.
