Home Forums Products Stompboxes Communication error? Reply To: Communication error?
#154966
bohan
    orestis wrote:
    Yes I did the process as you mention above, the update happen succesfull but still I am dealing with communication error problems.
    The eventide unit fail from the desk, and i will go to the support in Greece and check if this is the case.
    It could be that. You are using USB for connection right? Does Bluetooth work?
