Reply To: Can I plug H9000 on this DAC?
Home Forums Products Rackmount Can I plug H9000 on this DAC? Reply To: Can I plug H9000 on this DAC?
#154971
techno
jbamberg wrote:
techno wrote:
https://www.thomann.de/gb/steinberg_ur24c.htm
Can I plug it there? I only need my monitors and my Magni 3 headphone amp. I don’t play any instruments, it’s to be used as an effects procesor for VSTi’s all in the box. I would like to automate the h9000 as if it was an VST plugin. Am I lacking connections with the UR24C?
It looks like the UR24C doesn’t have any digital IO.  Are you using a Mac or Windows PC?  If it’s a Mac, it should be possible to use a CoreAudio aggregate device, giving you 16 channels of IO to the H9000.
Im running Windows 10. So what do I need that is similar to UR24C? I was told I didn’t even need it because the h9000 is a DAC it inself and I could just plug it with USB on the PC and then plug the Magni 3 there on the h9000 or something
