Home › Forums › Products › Stompboxes › H9 with an expression control and a footswitch › Reply To: H9 with an expression control and a footswitch
June 10, 2020 at 11:14 pm
#155101
bohan wrote:
akirabass wrote:
Hi, Bohan,
Thanks for your reply. Yes, I’m trying to built an expression/footswitch pedal on my own because I don’t need that bulky wah-wah-style pedal and don’t need to operate the expression control like I do on a wah pedal.
You should wire tip to expression pedal and ring to your aux switch. You also need to set H9’s EXP PDL setting to [EXP+AUX].
Show More...Thank you! So, my initial schematics seems to work!
