Home Forums Products Rackmount Eclipse ADAT FX Routing Reply To: Eclipse ADAT FX Routing
#155186
    belensky wrote:
    Can I somehow route FxA and FxB to different stereo ADAT outputs.
    Sorry, no. While the Eclipse has two internal stereo effects, it is essentially a two channel box, so you only get one stereo output.
    This is why on UM p.27, the ADAT options are:
    Thru The selected ADAT channel will carry the same signal that the corresponding ADAT input carried.
    Mute The selected ADAT channel will carry silence.
    Ch 1 The selected ADAT channel will carry the Eclipse’s channel 1 output.
    Ch 2 The selected ADAT channel will carry the Eclipse’s channel 2 output.
