Home Forums Products Stompboxes Using Expression Pedal for Volume Reply To: Using Expression Pedal for Volume
#155222
apalazzolo
    One more thought:  There shouldn’t be any lag-time with your expression pedal.
    If you are experieincing lag-time with your expression pedal, it might be because you are running your preset off of your control app via wifi.
    You should make sure to load your presets into your H9 first and make sure you are running a preset loaded into your H9.
