Home Forums Products Rackmount H8000FW boot loop problem Reply To: H8000FW boot loop problem
#155287
    Alas, I see no evidence that the NVRAM is at fault. It is more likely that the main ram is the problem (4 chips). As you say, could also be the boot rom.
    While U106 does not look great it is probably OK. See if pressing hard on it makes a difference.
