Home Forums Products Stompboxes H9 – freezing up when using app + midi cc at same time Reply To: H9 – freezing up when using app + midi cc at same time
#155314
Shor
    Thanks for the reply!
    To clarify, the device will still work and the current settings are still active, but i can’t change anything, or even bypass the effect without powercycling first.
    Anyway, it’s not a big issue, but I wanted to get some clarity on if it was a known thing or if it was intended to be able to use both bluetooth with app, and other midi cc control at the same time.
    Thank you! 🙂
