Home › Forums › Products › Stompboxes › H9 – freezing up when using app + midi cc at same time › Reply To: H9 – freezing up when using app + midi cc at same time
July 9, 2020 at 5:20 am
#155316
I do notice that if I just use normal means of contronlling cc it’s fine. But if I sequence midi cc it can do a lot more changes than you’d normally be able to do by hand, and that just seems to choke it.
If I actually don’t sequence it, but just turn midi cc knobs it works fine in conjunction with the app, but once I hit play on my sequencer and let it go, it’ll just choke the H9 (if bluetooth is also active with the app).
If I only run my sequencer it performs like a champ though.
Thank you for your input as well, as it’s nice to hear other experiences.
