Reply To: 9000 Series Can’t Change Patches Via MIDI?
Home Forums Products Rackmount 9000 Series Can’t Change Patches Via MIDI? Reply To: 9000 Series Can’t Change Patches Via MIDI?
#155325
jfirlik
mechanyx wrote:
Thanks for the quick reply. I'm not sure I completely follow your response though. In the Orville I have a patch called Resonechoes and another one called Crystal Caves. If I make those two patches in the H9000 or H9000R and connect it to a MIDI controller, can I then switch between the patches via the MIDI controller? Thanks
Essentially yes, however the mapping of MIDI message –> program load needs to be configured using the Scenes functionality before being able to do this.  So, the H9000 can do this through the front panel, and the H9000R will be able to do this in the near future with an Emote update.
