Home Forums Products Rackmount H9000 with two Dante cards Reply To: H9000 with two Dante cards
#155439
cyborgssc
    jbamberg wrote:
    This should work fine.  The cards will appear as two separate 32 channel Dante devices on your network.  As you probably know, the Dante ports in the back are in pairs and each pair is connected to an internal network switch, so you can daisy chain the two cards (you don’t need to run two ethernet cables back to your main switch).  How is your studio’s clocking set up?  The most common configuration in a pure Dante setup would be to let Dante take care of the clocking and set the H9000 clock source to follow one of the two cards.
    Great, thanks. My H9000 is already clocked to the Dante network – everything in my studio is Dante.
