Home Forums Products Stompboxes H9 Max Problems – Right Out Of The Box Reply To: H9 Max Problems – Right Out Of The Box
#155452
bmagsayo
    bohan wrote:
    If you reinstall the latest firmware using the Direct Updater through USB, it should fix this issue.
    The Direct Updater is bundled with the H9 Contorl.
    Mac: Click Window -> Open Direct Updater in the menu bar
    Windows: You can just search “Direct Updater” in your Start menu of find it in the H9 Control folder
    Firmware reinstalled… FIXED!!  I didn’t check all the presets yet but the first 20 or so are all on point.
    Thanks for your help, greatly appreciated.
