Home › Forums › Products › Plug-Ins › Shimmer plugin › Reply To: Shimmer plugin
August 5, 2020 at 3:54 pm
#155476
Could you take a screenshot or provide a preset of the settings where you aren't hearing 100% wet? Due to hardware differences, the pedal / plugin might sound slightly different, but I wouldn't expect the wet/dry mix to be affected.
H9 Control should export .tide presets, if you export them one at a time using the "Export Preset" button in the Presets view of H9 Control. You can then load these through the "LOAD" button in the ShimmerVerb UI. Renaming the .h9z file to .tide won't work, unfortunately.
