Home › Forums › Products › Stompboxes › Short Phrase Looping Techniques – Stompboxes › Reply To: Short Phrase Looping Techniques – Stompboxes
World-class necrobump here. A variation similar to Post #25 here, but not quite.
MIX set rather high, as the effect is part of the performance. NOTE 1-4 sets the LP/HP filters.
Expression pedal required. Trailing delay at the heel. Frozen 1-second loop at the toe.
EXP PED HEEL
EXP PED TOE
But the key here lies in what you ‘capture’ in-between. Delay time [LENGTH] increases along with FEEDBACK, so all of those delay glitches & stutters get locked into the FREEZE loop.
Show More...Holding at toe allows dry input over the frozen loop. Expression pedal movement gives you dynamic mixing control over current repeats added to the toe loop. Full heel fades it all out again.
