Home Forums Products Stompboxes Connection two H9 via MIDI port with software H9 Control Reply To: Connection two H9 via MIDI port with software H9 Control
#155503
bohan
    LagPhil wrote:
    Of course, I use the MIDI inputs and outputs because it works with a Ventris reverb.
    It is only when I connect two H9s together only.
    I am on Windows 10
    Can you try in your office ?
    Sorry I don't understand what you are trying to do here. If you connect both MIDI ports to your PC for H9 Control connection, how do you connect you H9 to other MIDI devices?
    If you'd like to use other MIDI devices with your H9 while using H9 Control simutaneously, the only option you have is Bluetooth. If you just need to use H9 Control for managing presets/change settings for your 2 H9s, I recommand you connect to the USB ports on your H9s to do so.
