Home Forums Products Stompboxes Connection two H9 via MIDI port with software H9 Control Reply To: Connection two H9 via MIDI port with software H9 Control
#155511
LagPhil
    The problem is always when two H9 are connected.
    I think that you have a bug about Thru parameter MIDI. It is not correct.
    Examples connection with MIDI port only :
    1 – Output MIDI port PC > Foot Controller MIDI FCB 1010 > H9 (parameter Output on XMT) > Input MIDI port PC = H9 Control works correctly with a H9
    2 – Output MIDI port PC > Foot Controller MIDI FCB 1010 > H9 (parameter Output on Merge) > Ventris reverb > Input MIDI port PC = H9 Control works correctly with a H9
    3 – Output MIDI port PC > Foot Controller MIDI FCB 1010 > H9 Core > H9 Max  > Input MIDI port PC = Only a H9 is visible in H9 Control (see table below)
    4 – Output MIDI port PC > H9 Core > H9 Max > Input MIDI port PC = Only a H9 is visible in H9 Control (see table below)
