Home › Forums › Products › Stompboxes › No audio pass-through at all in pre/post setup (modfactor) › Reply To: No audio pass-through at all in pre/post setup (modfactor)
August 22, 2020 at 1:33 pm
#155601
EyeballJackson wrote:
I'm having difficulties with pre-post setup on my modfactor.
After carefully configuring the cables, I'm not getting any audio throughput at all, whether active or in bypass.
Is there a setting that isn't compatible with pre/post that I might have activated without realizing it?
Do you get any signal if you just use IN 1 & OUT 1 or IN 2 & OUT 2?
