Home › Forums › Products › Rackmount › H9000 MADI 96k › Reply To: H9000 MADI 96k
August 26, 2020 at 10:00 pm
#155630
drxcm wrote:
If I’m running multiple units in a madi optical chain, does the H9000 have a selector for where it goes in the chain to adjust for latency? I have an SPL Madison converter too. It can be selected as 1,2,3 or 4 in the chain. Planning to put H9000 first and Madison 2nd. Just wonder if the H9000 must go first or can it go further downstream?
It probably makes the most sense to put the H9000 first in the chain. So, assuming that means you are using MADI channels 1-8 for the H9000 and 9-32 for the other devices in the chain, you would use Direct IO to route MADI In 9-32 to MADI Out 9-32 on the H9000.
