Reply To: H9 Control Creates New List on Every Save to Tablet
Home Forums Products Stompboxes H9 Control Creates New List on Every Save to Tablet Reply To: H9 Control Creates New List on Every Save to Tablet
#155749
bohan
axman53 wrote:
So when I do it that way, I don't get the multiple lists saving like before. So, that's good. However, when choosing (selecting) a list from the tablet to work on, it seems random which pedal a preset will load to while I'm editing it. Is there any way to set an affinity between a list and a pedal? Again, I'm using two H9s remember. Thanks.
When you connect 2 H9s in H9 Control, on the left you should see a column of 2 H9s. The active one will be highlighted there. You may just click the H9 that you'd like to work with. When you edit a preset, the highlighted H9 will load that preset.
