Home Forums Products Stompboxes Can H9 control Timeline ? Reply To: Can H9 control Timeline ?
#155781
bohan
    Thomas.jaw wrote:
    Like i wrote….I have read the instructions but do not understand any of it 🙁   Can you help me step by step ? Is there anything I need to set up in Timeline?
    https://s3.amazonaws.com/com.eventide.downloads/Product+Manuals/H9-UserGuide.pdf
    On page 40, you'll need to turn on this setting:
    [PGM.XMT] – MIDI Program Change Transmit Enable (ON, OFF) Press the HOTKNOB button to select. Turn the Knob to set MIDI Program Change transmit ON or OFF. If ON, a MIDI Program change message is transmitted whenever a Footswitch is pressed for Preset load.
    Timeline should receive MIDI PC messages by default so I guess it will just work. If not, you may need to ask Strymon or turn on its MIDI PC receive or something.
